Well today I finally dug into it. This by far is the worst water pump that I have ever removed from a VW/Audi vehicle. Do you notice what is wrong with the old Vs new pump?
I did finish up the water pump and timing kit today.
The next step will be to pull the plugs and do a compression test. If all is good, then I will replace the chain tensioner also.
There will be engine mods and tuning to come. Should be a fun build.
By the way if anyone has a spare 1.8t 225 engine code AMU lying around please let me know.
