mk2vr6 swap
Re: mk2vr6 swap
Post by Mikewire » Feb Mon 08, 2016 2:44 pm
SweaterVest wrote:Fitted a b3 pedal box, brake booster and cut out a hole for the clutch master this weekend.
OOO I bet cutting that hole in the firewall was a pucker moment :)
I'm surprised that it's not a grommet.
2017 VW GLI
Re: mk2vr6 swap
Post by SweaterVest » Feb Mon 08, 2016 2:52 pm
I kinda was too. It wasn't to bad. I just went real slow with a die grinder
benno3231
Re: mk2vr6 swap
Post by benno3231 » Feb Tue 09, 2016 4:36 pm
Yeah you did better than me. I went way too fast with a hole saw
Re: mk2vr6 swap
Post by SweaterVest » Mar Sun 06, 2016 12:31 am
Got to work on this today. I got the o2j shift box and cables modified and fired in to the mk2 today. Image
From underneath. It was crazy how smooth this went, every hole I drilled ended up being right where I needed it to be... That never happens.
I fabbed up this bracket for the rear.. Again it all fit the first time?? Image
So cool seeing the six speed knob in my mk2!
I also ordered my forth set of park brake cables. Again they were too long. So I decide to shorten then because I'm so frustrated that I can't find the right cables to fit. So after toying around with a few different I found a couple of barrel clamps for an air cooled throttle cable. Image
I haven't adjusted them how I want them yet but once I do I think I might fold them over and solder them in place.
All and all today was a good day.
Re: mk2vr6 swap
Post by MT-Getto » Mar Mon 07, 2016 10:59 am
Rad!!!!
Re: mk2vr6 swap
Post by SweaterVest » Mar Mon 14, 2016 1:34 am
Redid my VR6 harness this week. This is how it started. Image
My pile of "extra" wires lol.
Before I installed it in the car rewrapped it and spent some time under the dash plugging it all in with the OBD2 port. Image
Also installed all the break lines, bled those and replaced a torn steering rack boot.
I ordered a lightweight steal solid mass flywheel and related for the o2m from Four Seasons Tuning. They seem to be the only people that make one that's not aluminum. It's still like 16lbs but it beats the stock dual mass that pushing almost 30lbs I think. I'm pretty sure after a little bit of cleaning and installing the clutch I'll be able to put the engine in
Re: mk2vr6 swap
Post by MT-Getto » Mar Tue 15, 2016 6:59 am
Got my clutch from them too :)
Nice work there. Cool to see something taking shape :)
Leifro
Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI
Re: mk2vr6 swap
Post by Leifro » Mar Sat 19, 2016 7:08 pm
Pretty sure I have a few sets of parking brake cables. That's weird they send u the ones that are too long. If yours were still long I'd be interested in the for my caddy
Leifro
83TCQ-85S1
90Corrado-83GTI
Re: mk2vr6 swap
Post by Leifro » Mar Sat 19, 2016 7:13 pm
The brake booster, clutch pedal assembly and those retaining parts came from keegans old b3 passat wagon if anyone was wondering how those just appeared out of thin air
Re: mk2vr6 swap
Post by SweaterVest » Mar Sat 19, 2016 8:10 pm
Nope, I 'fixed' them as seen above.
