Cancer help
Cancer help
Post by bigmontana » Aug Tue 26, 2014 10:21 am
So seeing as it is not a dub or audi. I wasn't sure here to put this.
I was wondering if anyone has dealt with cancer a lot. I can replace the fenders but the quarters im not sure what do do. I was going to sand it to metal apply por15 and the repaint.
Any ideas.
NImageImageImageSent from my SAMSUNG-SGH-I337 using Tapatalk 2
Re: Cancer help
Post by bigmontana » Aug Tue 26, 2014 10:22 am
More
Re: Cancer help
Post by YASHA7FOLD » Aug Tue 26, 2014 11:46 am
You would have to grind it down to see how much sheet metal is actually bad.
Re: Cancer help
Post by bigmontana » Aug Tue 26, 2014 12:20 pm
Thats what I was wondering. I was thinking just sand down to metal. I have a grinder just don't trust myself. I dont want to cause a bunch of holes but need to fix it.
benno3231
Re: Cancer help
Post by benno3231 » Aug Tue 26, 2014 2:40 pm
I've used a sanding wheel on my grinder before and that seems to be the best way to go. takes away the loose stuff and leaves the good metal
http://www.mscdirect.com/product/detail ... 0=02555209
Re: Cancer help
Post by bigmontana » Aug Tue 26, 2014 3:15 pm
Sweet I'll have to get one thank you. Is that the exact one you use. It seems as if 60 grit is a little rough. That's what I was hoping someone had done before.
benno3231
Re: Cancer help
Post by benno3231 » Aug Tue 26, 2014 4:39 pm
That wasn't the same one I used but it looked just like it. I don't remember the grit, but i got the wheel at walmart. its the skilsaw brand one. even if its a heavy grit, it won't eat through good metal unless you really work at it. Just start off slow with low pressure.
Re: Cancer help
Post by bigmontana » Aug Tue 26, 2014 5:23 pm
Ok i have a grinder. Ill go to O'Reilly and get a disc.
Re: Cancer help
Post by YASHA7FOLD » Aug Tue 26, 2014 8:10 pm
I didn't mean a grinding wheel. Use an abrasive wheel. The same I use on my Beetle.
Re: Cancer help
Post by bigmontana » Aug Tue 26, 2014 8:33 pm
Right i have a grinder but an abrasive wheel. I should be able to use my grinder correct.
