020 AGB tranny question
Jd3
Silky Johnson
Silky Johnson
Vehicles: emgay4 sixbangr
88 16v prjct bloodysteak
Post by Jd3 » Mar Thu 24, 2011 3:52 pm
The backup sensor switches on these two tranny s are different but they are the same code as above. As you can see from the picture there are two styles of plugs. CE1? CE2? The one on the left is out of an 87 GTI, the right is an 88. Both 16v cars. Needed to get to the bottom of this before i start my wiring harness stuff. Trever, Brandon, Renty?????? holla :thumbsup: :beer: Second off, Can I totally delete this because of the digifiz I will be running. Dont believe there is a reverse/upshift display? Josh just made a valid point as well. Would this be for the reverse lights? thanks again
Re: 020 AGB tranny question
Post by Checkers » Mar Thu 24, 2011 4:30 pm
It is for reverse lights only.
Are you sure they are both the stock trannys? I'm thinking one is a MK1 020 and one is a MK2 020.
Post by Darkside » Mar Thu 24, 2011 4:33 pm
dont believe either car had a tranny swap... both have the AGB code, which i believe is Mk2 :banghead:
this is jurgen.....
Post by Roadhog » Mar Thu 24, 2011 5:22 pm
It's for reverse lights. If you don't want reverse lights don't connect it.
Jd3
Silky Johnson
Silky Johnson
Post by Jd3 » Mar Thu 24, 2011 6:09 pm
disregard the delete part of it... everyone needs backup lights. I thought it was only for the display on the instrument cluster. Once i get them back from the media blaster, im going to re look up the codes. But Im a 100% positive that they are both 100mm flange 020 AGB trannys
Jd3
Silky Johnson
Silky Johnson
Post by Jd3 » Mar Thu 24, 2011 6:14 pm
found my answer... and im an idiot kinda... Just hope my KR wiring harness has the plug for it....
http://www.germanautoparts.com/Volkswag ... ion/203/13
http://www.germanautoparts.com/Volkswag ... ion/203/14
Post by Roadhog » Mar Thu 24, 2011 7:33 pm
Jd3 wrote:disregard the delete part of it... everyone needs backup lights.
Tell that to my Corrado. :p
Jd3
Silky Johnson
Silky Johnson
Post by Jd3 » Mar Thu 24, 2011 7:38 pm
we could spend all day talking about things that dont work on any given corrado... :p
Post by kompressorgolf » Mar Fri 25, 2011 9:34 am
i forgot about back up lights long ago. if they work cool, if they dont, i dont care.
A8L, RAM
Post by MT-Getto » Mar Fri 25, 2011 9:54 am
Back up lights are a good thing. Up Shift indicator is usually vacuum. I think some of those switches also do neutral and 5th for the UP shift too.
