Electronic Boost Gauge
DynoJetta
'03 Jetta TDI (RIP)
Post by DynoJetta » Jan Tue 12, 2010 4:06 pm
I've had this built for a while, but I've been slacking getting some pictures posted. (if this is in the wrong spot, feel free to move it Mike).
Rundown:
I'm using a Wideband2 to translate my MAP Sensor analog signal into boost (gauge psi). I'm using one of DynoJet's LCD displays to display it.
I originally designed and built a gauge mount that goes in the circular vent on the dash near the pillar (G14 classified, so no pics ;) ). I decided I didn't like the idea of it being near the airbag so I built a mount that goes in the middle of the dash on the defroster vent. (I designed and fabricated the whole thing out of aluminum). I need to take it apart and repaint it, but it's been working real nice. Maybe I'll look into getting it anodized (I recall seeing a new member that has everything for that).
Image Image Image Image
short crappy video showing it in playback mode:
[youtube]http://www.youtube.com/watch?v=_WcJRwBZFTE[/youtube]
The feature I like the most about the display is I can data log my boost and export it to excel for graphing and such. I have an EGT probe on hand, so as soon as I get it installed, I'm going to pipe it into the display also. Most likely I'll display EGT as a bar graph or digital readout, but we'll see when I finally get it setup.
I need to do some work on the sample and averaging too, that way I can get a smoother needle sweep.
And if anyone's curious, no I am not running an wideband oxygen sensor on my car. Not really practical on a diesel. I'm simply using the analog input feature on the WB2.
Re: Electronic Boost Gauge
Post by Mikewire » Jan Tue 12, 2010 4:19 pm
Tight! very nice!
2017 VW GTI | APR Stage 2
Post by kompressorgolf » Jan Tue 12, 2010 6:47 pm
looks nice josh!
A8L, RAM
Post by MT-Getto » Jan Tue 12, 2010 7:41 pm
Sweet!
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat » Jan Tue 12, 2010 8:22 pm
Josh, nice! I'll have to walk over and see it in person.
Too bad that cable doesn't come out the back of the display, huh? ;)
-Joe
My cars
DynoJetta
'03 Jetta TDI (RIP)
Post by DynoJetta » Jan Tue 12, 2010 9:57 pm
ValveFloat wrote:Josh, nice! I'll have to walk over and see it in person.
Trust me, I looked into modifying the case and hardwiring the cable in. Just wasn't going to work. ;)
DynoJetta
'03 Jetta TDI (RIP)
Post by DynoJetta » Feb Fri 18, 2011 1:26 pm
Time for an upgrade.
As stated above, I've been running this thing using a Wideband 2 to translate my MAP analog signal into Boost (gauge psi). At the time it was the only thing we had setup to communicate with our LCD. Since then, with the release of newer products, we now have our LCDs configured to communicate with our PowerCommander V.
What that means for this little project:
1. I now have 4 analog inputs that I can configure and display on the LCD (WB2 only had 1)
I'm going from displaying just Boost to now also having Throttle position and EGT. I have to source some connectors, but I also plan on displaying MAF (i'm not too crazy about posi-tapping it, but I might have to).
2. With each input I have greater control over not only the transfer function, but also the sampling and averaging.
On the WB2, you have a table with two rows so the only thing you can put in are the lowest and highest transfer values. On the PCV you can have between 2-10 rows on your table. This translates into a more accurate transfer function. With the data acquisition I did, I now have 8 tables. (BTW if anyone could track down a data sheet for the 2.5bar Bosch sensor 0281002177, you'd be my hero!)
The sample and average control is really nice. As you can see in the video above the "needle" is very jumpy. I never could track down what the WB2 was hardcoded with, but I've now cranked the sampling and averaging up to where it has a nice smooth sweeping motion. Not only that, but steady state is much more stable.
As I have to pull my intake off to put in my EGT probe, I've had my probe sitting on my desk for a year now. Now that I have everything upgraded to display it, I have more motivation to finally get it done.
Once I get everything hooked up I'll post a new video. :D
Post by padroB5 » Feb Fri 18, 2011 1:35 pm
can wati to see the new video i have been intreged with this set up!
