brake job 92 golf
brake job 92 golf
Postby t-dubbin on Mar Fri 23, 2012 9:36 am
i have come across some calipers for converting my rear brakes to disks. was wondering what kind of parts i need and approximate cost for the whole setup? do i need to change spindles or do the rotors just slap on?
also wondering if anyone has a mk3 weighted shift linkage they want to part with??
thanks guys!
t-dubbin
Re: brake job 92 golf
Postby kompressorgolf on Mar Fri 23, 2012 10:06 am
you need spindles too, thats what the calipers bolt to. youll need e-brake cables, the correct rubber lines-rebend the steel lines a little, install proportioning valves, its quite alot really, and really 0 gain besides looks.
Postby Rennwagen1 on Mar Fri 23, 2012 4:54 pm
I may have the spindles and some other random parts for the swap.
Postby digsmk3 on Mar Sat 24, 2012 10:43 am
I have the whole set up on my parts car if that doesn't work with Rennwagen
digsmk3
Postby t-dubbin on Mar Mon 26, 2012 2:41 pm
well i think ill just repair the drums and focus on fixing all the loose ends i have...
t-dubbin
Return to Golf II & Jetta II
