RADO IS BLOWING UP! PLZ HELP!
Discussion area for all Corrado models
Moderators: Mikewire, Roadhog
Re: RADO IS BLOWING UP! PLZ HELP!
Post by Roadhog » Apr Tue 20, 2010 6:53 pm
DrewG60 wrote:
Roadhog wrote:
DrewG60 wrote: it appears to be dripping on the header which makes for a nice plume of smoke.
And then a fire.
a fire???? you must be joking....how can i fix this?
No.. Oil + very hot surface = fire.
DrewG60
Vehicles: 1990 VW Corrado G60
Post by DrewG60 » Apr Tue 20, 2010 6:56 pm
well yes i know that... thts why i am not driving it for extended periods of time.
a great man once said..."F**K a HONDA!" oh wait, that was me...
Post by Roadhog » Apr Tue 20, 2010 7:11 pm
driving it at all is asking for a fire...
Post by padroB5 » Apr Tue 20, 2010 10:35 pm
i was thinking about getting some oil/engine dye for it an maybe have some more luck or so....
Post by Rennwagen1 » Apr Wed 21, 2010 11:23 am
Roadhog wrote:Image
Or someone had finally had it with their corrado?
vrtpassat
Post by vrtpassat » Apr Wed 21, 2010 1:14 pm
DrewG60 wrote:
vrtpassat wrote:
DrewG60 wrote:Also, the engine is remaining cold for some reason. Just another piece of info for the equation
is this what the gage is telling you or have you felt the engine it might be for this problem a bad sending unit gage is messed up or broke wire unless you have a fail safe termast in wich when they fail they fail in the open position as to not over heat the engine
good luck i wish i could help more but you are a ways away :beer:
it was the gauge...due to coolant leak... found and fixed. everything is now fixed except for oil leak. its very small as I am not losing a noticeable amount of oil however *from a novice's perspective* it appears to be dripping on the header which makes for a nice plume of smoke.
it is probly a vale cover gasket or cam seal is the head an they 8 valve g60 or have you put the 16 valve head on
DrewG60
Post by DrewG60 » Apr Fri 23, 2010 6:27 pm
8 valve
