O1E discuss
This discussion forum is for any general discussions related to all makes and models of Audi.
Leifro
Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI
O1E discuss
Post by Leifro » Feb Mon 08, 2016 10:26 am
Let's gets some information sped around while we all still have the brain cells on this kinda stuff.
Recently learned: an O1E 5 speed can have a 6th gear added into the case with just the simple acquiring of the gear itself.
All O1E ' s reverse is in the same spot as most mk1 - mk3 vws as a dead give away.
All 2000 and newer 6 speeds are 01E, also euro spec
Anyone out there with euro gear info weight in.
benno3231
Re: O1E discuss
Post by benno3231 » Feb Mon 08, 2016 1:24 pm
The early O1E's in the UR cars had problems with first gear making noise and sometimes going out. I believe mid '93 they fixed this issue. I had no idea you could add a sixth gear to these!!
Re: O1E discuss
Post by SweaterVest » Feb Mon 08, 2016 2:55 pm
Isn't the 01E a Passat transmission? I don't think they put it in mk1-3 cars
Re: O1E discuss
Post by Roadhog » Feb Mon 08, 2016 8:03 pm
huh? isnt that an audi/passat awd transmission?
Leifro
83TCQ-85S1
90Corrado-83GTI
Re: O1E discuss
Post by Leifro » Feb Tue 09, 2016 3:34 am
No Wes they didn't put one in a mk1- mk3 car. The O1E ' s reverse is in the same sspot though as a 020. Down left then forward. I know the newer passats run a trans similar to an O1E, 01X may be the code. The casings for all 01E ' s also are the same with some even have a oil cooler
