pisstons or headshim
- vrtpassat
what should i run pisstons or a headshim on the new build up the vrt or should i run bolth any info could be helpfull i allready now witch dose what but need help deciding
Moved to the correct forum. I say go pistons - more $ but worth it. How many miles on the motor?
2017 VW GTI | APR Stage 2
Re:
There are guys running 400+ with a head spacer. That's my goal with the 42# injectors. are you going to be using some sort of software or stand alone?vrtpassat wrote:allmost 200k but i have herd of vr6 bottem ends holding 350hp with stock internals and the right head shim
92 Corrado SLC VRT that goes KAAABOOOOM
87 Toyota Poopra
89 GTI VR6
87 Toyota Poopra
89 GTI VR6
- ValveFloat
- Vehicles: 1991 911
Re: pisstons or headshim
I do believe you will need pistons.vrtpassat wrote:what should i run pisstons or a headshim on the new build up the vrt or should i run bolth
Unless you are going rotory
- vrtpassat
at the moment i am leaning tward cis but kind of spendy
not shure yet it is still a long way from needing the turbo again
I see what you did there, Joe. You are funny.
- vrtpassat
i see it now that arin pointed it out that is a prity clever joke very funny hahaha
