CAI: FAQ's, truth and lies...
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat » Dec Tue 04, 2007 2:42 pm
ValveFloat wrote:My actual experience with this is slim to none
I just realized I lied.
I removed the airbox from my 125cc scooter and put a UNI filter on the carb, pretty much the same concept as a filter-on-a-stick.
Picked up 1.3hp, a 20% increase :mrgreen:
Post by Roadhog » Dec Tue 04, 2007 3:22 pm
Yeah I have a UNI on my 125cc dirt bike.. It was a day and night difference.
But thats a little different than a filter on a stick in a hot engine bay. :nod:
Post by Rennwagen1 » Dec Tue 04, 2007 7:28 pm
Wait. Joe, you dyno'd a scooter? You are a true OG.
Post by Roadhog » Dec Tue 04, 2007 8:08 pm
My dirt bike would be interesting to dyno.. I bet it puts down over 50hp...
Post by kompressorgolf » Dec Wed 05, 2007 6:58 pm
ive seen a pocket bike get dynoed before, simply amazing
thetwodubheads
Vehicles: 2012 Golf TDI, 2010 Ram 2500 Cummins
Post by thetwodubheads » Apr Tue 08, 2008 6:59 pm
I use a filter on the MAF, pretty much just for throttle response, and sound. On newer cars, the airboxes are usually designed pretty well and aren't a restriction. At least for performance cars. Hot air intakes really don't matter on a turbo car, since the drag of long piping to the turbo pretty much negates the gain from cooler air. Hell the turbo can heat the air up to 300 degrees under high boost. So that 15-30 degree difference to the pre-pressurised air doesn't really matter.
On a NA engine, it can help though.
However while cruising usually the bay isn't nearly as hot as when you are sitting in a parking lot showing off the car.
Post by bigmontana » Apr Tue 08, 2008 11:09 pm
What cars should they not go into or is basically every motor VW makes OK?
thetwodubheads
Post by thetwodubheads » Apr Wed 09, 2008 12:31 am
Big Montana wrote:What cars should they not go into or is basically every motor VW makes OK?
From my readings on a few other sites, it seems anything from VW and Audi from 98-99ish (MK4 and B5 chasis) up seems to have very little if any effect on power. They may yield a couple up top, but nothing noticeable to the butt-dyno. I know I can't tell a difference in power from the stock airbox to the K&N I put right on the MAF. I can feel a slight improvement on immediate throttle response, but that could probably have more to do with the factory filter than airflow.
Post by bigmontana » Apr Wed 09, 2008 9:25 pm
Cool thanks
hollaback
Re: CAI: FAQ's, truth and lies...
Post by hollaback » Aug Thu 20, 2009 8:57 am
helmholtz resonance intake :paranoid:
