1990 vw fox valve cover gasket...
Locked
enjoyphill
Post by enjoyphill » Mar Sun 14, 2010 4:02 pm
i have a 1990 vw fox 1.8L Fuel injected...
I picked up two cork valve cover gaskets from o'reilly auto parts...
after removing cover i proceeded to clean both the head and cover-was able to get head (with help of a gasket cleaner) baby butt clean, but the cover was alittle more diff. to get to that same level. i ended up using a razor blade to carefully scrape off residue which had, o0ver the 200 some thousand miles of driving, seemed to chemically bind to the cover - i was carefull not to let the blade warp/cut the cover in any way.
after seating the gasket i proceeded to put the cover back onto the engine.
this is where i might have messed up...
unaware of the torque specs or assembly order i screwed the bolts on by finger and proceeded (with a counting of turns method) to tighten with my trusty socket wrench.
after i thought all was well and done i was filling the well with oil and noticed a a stream of oil coming out of the furthest back,left bolt (on the downside of the angled block). im guessing because of the engines tilt the oil just moved to that spot and began leaking out...but why just there? other potential weak spots on that same side seemed to hold the seam...
removed that gasket and replaced with 'gasketmaker' - that all went to hell when i noticed oil coming out of the entire left side of the engine...it appears that the cork was doing a better job...
i need help
any thoughts or ideas?
Re: 1990 vw fox valve cover gasket...
Post by padroB5 » Mar Sun 14, 2010 7:07 pm
i am wondering if the bolts are one time use only. i know some heads are like that because they strech so you might want to look in that posabilty. an see what the specks are an maybe replace the bolts an the sequens they are so post to be tightned in. looks like you cleaned it in the right fash tho from the soounds of it.
Post by Darkside » Mar Sun 14, 2010 7:30 pm
Valve cover bolts are not stretch bolts. You can reuse them. You may not have gotten them tight enough.....Pics would help
Post by kompressorgolf » Mar Sun 14, 2010 7:30 pm
jeez, something isnt right, there shouldnt bee that much oil up there anyways, it should all drain into the pan. any pics>?
enjoyphill
Post by enjoyphill » Mar Mon 15, 2010 9:31 am
i have some photos - how do i post images?
Post by Mikewire » Mar Mon 15, 2010 10:31 am
enjoyphill wrote:i have some photos - how do i post images?
Here you go
Kompressorgolf is right, from your description is sounds like there is something clogging the return oil passage in the head because the oil level in the head shouldn't be more than a steady stream of oil flowing back into the oil pan. Possibly old gasket material that has fallen into the opening and clogging up the passage, so I would pull the cover and take a look for any blockage.
Take a look at both sealing surfaces on the head and the cover and make sure all the old gasket material is removed and there is a smooth flat surface so the seal works correctly.
And I would stay away from the cork VC gasket and spend a little more to get the rubber one - it's reusable, seals better, and does not require any sealant so it bolts right up - just don't over torque the bolts.
2017 VW GLI
thetwodubheads
Vehicles: 2012 Golf TDI, 2010 Ram 2500 Cummins
Post by thetwodubheads » Apr Sun 11, 2010 11:30 am
Also, make sure to use just a drop of Black Automotive RTV at the corners of the half circle part that goes into the extra cutout for the cam.
Locked
